So the holes through the solder pads for solder pin pots don't fit the pins when coming through the back. The pins can sit inside it if the pot sits on the component side. Are the holes meant to be beveled or were they not drilled through all the way? If that's the case, should I try drilling the holes wider or should I just use wires and tape the board to prevent shorts if it moves (since it won't be fixed to the case)?
