Anyone ever have an issue with 3pdt footswitch? Ive built about 20 pedals and never had an issue. Just finished a hudson broadcast (duocast) build and if the bypass footswitch is not in the screw-hole, the pedal works fine. If i feed it through the hole (doesnt matter if i attach the washer) there is no noise. Something in the switch must be sending it to ground. This is only if the pedal is engaged. In bypass signal flows through fine
Anyone ever experience this? Im gonna wire in a new one and see if that works but figured id see if anyone here has seen this either.
Edit: solved. Led bezel issue when 3pdt was tightened
