SpinCAD Designer release 0.98-1038 - fixed crossfade 3 block
Digital Larry
I'm taking advantage of having opened up the code again to make some small fixes here and there. I never know how long the desire to do this is going to last.
This time, the Crossfade 3 block got fixed. It is fairly simple and I don't know how long I scratched my head trying to figure out what was wrong. But with a fresh set of eyes (or maybe it's these new glasses) I was able to track down the issue and fix it. It's always in the last place you look!
I had the two inputs mixed up for control input between 0 and 0.5, AND the big one was that I forgot that AFTER a SKP instruction, the ACC is not usually 0, so you probably have to add a CLR as the first instruction.
I also updated the pin names on the 2:1x2 mixer (stereo mixer) to make it more obvious which pins are getting mixed to which outputs.
