Hi Everyone,
I'm new here to using the forum and have never been a forum guy so bear with me as I learn my way around. I have a question for you: can the Sproing handle 18 volts? I accidently plugged in an 18 volt wall wart on stage this week. It blew out my Sproing. I checked all the parts and they should have handled 18 volts okay from what I read. I did discover that I used an L7805CV instead of the L78L05 power regulator. It was all working great until the 18 volts. Would the regulator make a difference? I thought they both can handle 18 volts and keep the output consistent at 5 volts.
I discovered all this when troubleshooting. The L7805CV was getting really hot. I replaced it with an L78L05, replaced a bad the 100uf and now I get guitar signal through the pedal (when it is on). I get no reverb but the Belton module shows continuity on pins 1, 2, & 4 so I have to assume it is shot too. I'm bummed. This was a great pedal and that was the most expensive part.
I will be building another but probably with my own PCB to fit into a 1590B.
Thanks,
Chris
Thanks,
Chris
