giovanni
- Build Rating
- 5.00 star(s)
I built this pedal to test it out for my upcoming DIY pedal building workshop. I wanted a simple fuzz with only two knobs and easy to find transistors, so I landed on this one. I also decided to try Tayda's predrilled 1590B, which are cool, but in my opinion poorly thought out: the 3PDT switch could be much lower in the enclosure, allowing to move the jacks lower too and thus providing a lot more room for the PCB. As you can see, I had to bend the pot leads to make the PCB fit on top of the jacks, which feels a bit gross! On that note, I wonder if anybody had a drill template for the Tayda drill service that could be used for this (side mounted jacks are OK with me, since it's just for a workshop). Unfortunately Tayda does not provide pre-drilled 125B with only two knobs (@PedalPCB can we do anything about that?) which would be ideal for this workshop. I just don't want to have to drill 10 enclosures myself.
Anyways, the build went pretty smoothly and honestly I rushed it a bit because I just wanted to get it done (I did forget to clean the PCB with IPA), but it all worked out right off the bat. I did notice what others have: with volume dimed, the pedal barely gets to unity. The sound is interesting but I have definitely played and own much better fuzzes than this one. I do like the green knobs and LED tho!
