Stockade Overdrive
bergera
Finally got this built. Was missing some diodes so did some subs. I get a decent drop in volume when rotating through them so I'll have to look at that.
Otherwise I like it a lot
Ok. Good to know. I thought maybe that was the case. I was also playing it through a small practice amp at low volume...
The combinations and boost make it a pedal I have been looking for a while. Hopefully it will preform as I think in a band setting later this week
I see some germaniums in there that will cause a volume drop, not sure how you laid them out. I usually use four diodes in series like this. You could always experiment, this is just one combination that works but you still get a slight volume loss.
yeah, on set is symmetrical and sounds good. The other is asymmetrical and definitely has a good volume drop.
