benny_profane
Which did you end up choosing?to my new headphones (thank you all for your input btw)
I chose the DT-880-Pro. They are comfortable enough and sound great!Which did you end up choosing?
	How can one learn such a power? The power of making a charger that is.Since my mower decided to die, I built a little battery charger since I had a free battery....sort of.
I've got it turned way down as those leads aren't going to take a lot of current, but it works. That little board under the DMM is a charge regulator I picked up at Tayda (though these are sold nearly everywhere)..thus the charger-on-the-breadboard. Unfortunately, the goop used to attach the heatsink was leftover PlayDoh from 1966, and the heatsink was loose in the package....also, it doesn't work so the heatsink isn't really an issue. I ran an audio probe through it, and it hissed at me. The only thing worth a hoot on that board is the relay, which is likely what is FUBAR.
Schematic...
	How do you test a pedal without soldering the pots? I have a few builds to test but I can't put the pots in as I don't have the drilled enclosures yet.I drilled an enclosure for it, assuming I’ll want to play it regularly, rather than on the FrankenRig™. I was out of A25 pots (of all things) so I was waiting to that so I can at least test it…I think it’s starting to believe it belongs on the bench. That guarded yellow eye with a smug & judgmental gaze…
Oh I don’t. Sorry if my post was garbled.How do you test a pedal without soldering the pots? I have a few builds to test but I can't put the pots in as I don't have the drilled enclosures yet.
I tried using breadboard jumpers attached to the pots with alligator clips but the connection isn't stable.
I just don't want to desolder anything. Even with the Engineer SS02 solder sucker, flux and wick, I still make a mess of the board.Oh I don’t. Sorry if my post was garbled.That said, I suppose I might be able find a suitable connector
Unless it’s some weird layout, I sometimes solder the pots before the enclosure arrives or is drilled. Switches can be a bit of a pain..but I’ve had great success.
The Whipped Cream Drive I’m also building has all three pots and the switch soldered…I haven’t even thought about an enclosure yet..LOL
I have a friend who works on Otis maintenance. I think more on the mechanical side. But let me know if you have questions, I can hook you up.Thank you! I‘ve got an upcoming countdown clock project with some Otis Elevator AN displays…it’s more of an actual project so I’m hopeful to have some fun with it.
It sounded like an electric sitar? Make sure to take note of those settings because I want emI forwent…hang on is that even a word? Apparently…anyway, I skipped testing and boxed the Phase II up, as I had a spare enclosure. I haven’t putzed with the trimmers or even put the cover on but with random pot settings it fired up and sound just like the opening of Bad Sneakers.
I’ll clean it up and post a report.![]()
