Something Buggin' me about this Pedal & it's appearance1It IS gorgeous! A friend of mine gave me that enclosure![]()
More info please!!!
What is the Brown one?
Are these not good enough for the Build reports forum???
It's a '61 Custom Shop Journeyman. Hand-wired Texas special pups, '60 oval C neck, 9.50 fret radius, grease-bucket tone. Extra relic'd neck back (man is it quick). It's very light...I don't have the weight though.So what is it? Custom shop? What are the specs? Do tell!
More info please!!!
Go figure, Tim has better off board wiring than most of the well-known members combined. Respect Tim, people could learn a thing or two looking at your builds.View attachment 23536
Thanks guys! Usually, once I start a build, if I have all the parts, I can finish it within a few hours...drilling and all. It's turning on the iron that takes so long.![]()
Try soft candle-light, a dozen roses, a magnum of Veuve Clicquot, Barry White in the background and rubbing gently with a mink-mitten…… It's turning on the iron that takes so long.![]()
That's Tayda's light violet. It came out pretty well with the little matching switch condoms (by the way, those 'pop' a tiny bit of air when you put them on or take them off...I thought I had broken the switch the first time I slid one one.)Wow that hydra looks lovely. What's that enclosure color?
Also love the tele. If you don't like it anymore, send it my way![]()
Looks just like the Original, just different Knobs & led!What a day for a daydream...
He does excellent work.Looks just like the Original, just different Knobs & led!
Your Friend did a Good job!!! :
Looks great!He does do excellent work.
I kinda like the white now that I see it...![]()
That’s rad (why is that so exciting to me? Sigh)!!!!I also built another little "cookie" jig. This one also uses a ZIF socket, but to hold 6-9mm pots for breadboarding...I've got some spring terminal blocks coming to test out as well.
You got it. I use a small database to store each (significant) component. I don't catalog passives because I'm not that far gone...no offense to anyone that far gone.Send pics of the sorting process, including the 144 compartment case. I'm about to measure a bunch of smd JFETs.
