This was a
part of my no-show entry to
@Chuck D. Bones ' Muffin Board design contest. It would never have stacked up to the competing entries (very cool stuff folks!) but I have had a good time putzing with it. I'll try to get the whole enchilada together soon. Then it will make more or less sense.
It's a Ruby with a twist. The input is a bluetooth module. I've been auditioning several of these embedded thing-a-ma-jigs . It also led me down a research hole regarding EM filtering and noise filtering in general. The realization of the magnitude of it was a bit intimidating, but as oft I do, off I went. I learned very little that would actually be useful in this application but I found something to study should I have another lifetime at some point.
Theology aside, it was a definite departure from what is typically deployed in a guitar pedal circuit.
The Muffin board's power stage and tone control
would have been used for the contest. The remainder of the project is still being completed. My actual bench time has been erratic so progress on ALL projects have taken a hit. No complaints. If life were predictable we'd be both boring
and bored all the time. Challenge accepted.
Thanks for reading.
Edit: You may notice a missing jumper from the BT output to the amp input...I pulled it for testing.....you can't run the circuit more than 3 minutes or it will melt the breadboard. Heat sinks help but only add another minute before your wife asks which air freshener you just used so she knows
never to buy it again!
