Hello! Has anyone else built the Sugarbag project? I looked around a bit on the forum and didn't see any chatter regarding it. I am curious how this one worked out for anyone else. I'm getting hardly any real gain from it unless the gain is turned about 80% up. Even then sometimes I'm noticing strange sag. Almost like when you hit a strong compressor really hard and it takes a moment to rebound. It can do some kind of interesting tones but it's a far cry from the range of sounds I've heard in the demos of the Fat Bee.
I sourced the ICs and transistors from Smallbear so I have faith they are of good quality. I was going to double check some of my part values but since the build docs are not posted and the board is soldered together that makes verifying all the values tricky.
Anything unique to watch for with this build? Any part changes or "gotcha" moments to watch out for?
