Hello!
I did not find a general "Welcome new posters"-thread, so I'll just start directly here (if there is one, sorry, I'll post there of course!).
Nathan from Sushi Box directed me to the forum, as I'm having troubles with my build of the Particle Accelerator. I did read all the threads on the build, but it seems I ran into something new
I think I got something wrong with the build, or maybe a component is not functioning properly, as the Bass-knob has no effect on the sound whatsoever (I measured the resistance of the potentiometer in 0 and 100 % position, the resistance changed from 0 to roughly 190 kOhm, so it should work basically). The capacitator in front of the potentiometer is charged. The connections of the potentiometer to the next parts of the circuit are conductive. The ground is also conductive.
There is absolutely no effect. No boost, nothing.
Also the Gain is not as effective as I would have thought, there is quite a lot of volume difference between 0 and 100 %, but not much compression or actual "overdriviness" (but maybe this is just how it is supposed to be, this is my first experience with a preamp from Fender/Alembic).
The rest is fine I think, footswitch, volume etc. The tube filiaments are glowing, and the signal is quite free from interference (with a Bass VI with single coils). I measured the voltage at R8/R9 , which is 250V (as in the instructions), therefore I assume that the high-voltage supply is working as intended.
Maybe you have an idea where I could check, maybe could you help me out the voltage values which should be measurable on the pins of the tube, ?
Thank you very much! If there are languange problems, please let me know, as I'm not a native speaker
Best regards, Ben
Best regards, Ben
