clipped_diode
Hello all — I built an Aion Azimuth kit a year or two ago. It is a Zendrive clone. The kit incorporates some pre-wired connectors as you will see in the images below.
Everything on the pedal works fine, except that the switch temporarily mutes the signal whenever it is in a sort of in-between position between on and off (or off and on — both directions). The signal cuts out before the *click* of the 3PDT. The LED also goes out in this in-between position when switching the pedal off. I can replicate this 100% of the time.
I don't remember if this was happening when I initially built the pedal. It was one of those projects that I completed and didn't really use for quite awhile.
Any ideas? Happy to upload a video if anyone thinks that will help. Thanks in advance for any tips.
Project documents:
Project documents:
