Aleph Null
This is my most recent design. I posted about it on the Mad Bean forum a week or two ago, but @jessenator says all the cool kids hang out over here, so I though I'd post here as well.
The enclosure is Aqua Vein from stompboxparts.com. It's beautiful, but difficult to photograph. I used the same cheeky graphics from the original version.
I'm starting to get my PCB layout conventions figured out and I think it shows in this build.
Version 2 implements a slow-opening mosfet switch which allows a “tails time” to be set before the delay signal is turned off. This maintains the tails bypass while eliminating the added noise you'd get from the PT2399 output begin connected all the time. Additionally, the input and output sections were streamlined and filtering was increased slightly. The modulation section was revamped to allow for a much greater range and to eliminate the need for a switch. It is essentially the same technology I implemented in the Special Sauce and Trogodyte Reverb. It uses the CCO voltage to control Q1, which is set up as a current sink (a variable resistor).
Here's a demo:
If any one is interested in a PCB, just PM me; I'll be putting in an order for another upcoming project soon, so I can order more of these then.
Here's a demo:
