Fama
Hello!
I've now had a set of enclosures printed and drilled at Tayda, and the results were pretty good. For normal use like that I've just used the "snipping tool" to copy the drill tool preview image to Illustrator to get the approximate locations of the pot holes correct, and that was just fine.
For an upcoming enclosure I was planning on doing a Moody Sounds Zeygot fuzz which apparently has a toggleable (depending on your build) mode where the fuzz oscillates unless you cover and LDR on the pedal's surface. I thought this was a very cool idea, and was inspired to do an "all seeing eye" style enclosure for it. However, I would like the LDR to be right in the, well, eye.
My question is, is the origin point on the drill tool and the print template exactly the same? As in, if the hole is at 0, -15 on the drill tool, if I put a guide circle for the same size (using the ellipse tool, handy for that) in the print file, align it horizontally and vertically (so that it's right at 0, 0) and then move it 15 millimeters down, does it line up perfectly?
I suspect it's at least pretty close, but comparing one of my prints I think it's possibly not exactly at the same spot. A small error wouldn't be too bad, but it's sort of going to ruin the theme if it misses the mark a bunch. Anyone have experience with this, or should I maybe email Tayda about it?
