Chuck D. Bones
Circuit Wizard
Yes. A drawing would be better, but I think you have it right. The buffer has to be after the Echoes switch.
Ahhh, the "lumpy cable." Would it surprise you to know that there are satellites flying with lumpy cables?
You need an anti-pop resistor after the 10uF cap because it goes to a switch in your circuit. You also need an anti-pop resistor before the 100nF cap since it also goes to a switch.
Biasing the gate to 1/2 Vcc is not the magic number, but it's close enough. FYI, the same buffer could be realized with a MOSFET.
Uh oh am I gonna have to rescind my previous statement?![]()
Sure. I didn’t have the generic board material so the PedalPCB was cheaper and, in my hands at least, will look cleaner.You could have Vero'd it and be done.
Good save on the input. Next time instead of scraping you could just jumper from the next component connected to that pad.
Which guitar are you using? Pickups, guitar volume, guitar tone and wah treadle position all interact. It's tricky to find the the settings that cause warble.
