cdwillis
I'd like to see someone take a noninverting op amp gain stage, test various clipping diodes in it at various amounts of gain, and use an oscilloscope to view the waveform. Would a red LED have a similar waveform to a set of 1n4148s (to match the same forward voltage)? Same thing with 1n4148 and germanium diodes like 1n34a. Plus take into account that different diodes start to conduct at different voltages and hard clip at others. I think there would probably be at least a slight difference in the wave form.
Also with op amps I bet the difference mostly be the input impedance of the op amp when you use diodes in the feedback loop. If you're using diodes at the output, you're going to hear the op amp itself distort before it hits the diodes and gets clamped. This is going to be at least somewhat if not very noticeably different between certain op amps. Try a TL071, UA741, and OP07 in a Rat or a DOD250 style pedal to see what I mean.
