I’ll measure it later today. Is that for a 5mm LED?Do you know which step you used to drill?
I have a few of these that are slightly larger than the usual 5mm bezel.
The pot one is too small. I haven’t tried a jack one, good suggestion!Did try a washer off a pot or jack?
I done the same thing (drilled the hole a tad too large). With a bit of filing, pot washers will work.The pot one is too small. I haven’t tried a jack one, good suggestion!
Or 10mm!
