Chuck D. Bones
Circuit Wizard
This circuit was inspired by the Lovepedal COT and Xotic BB Preamp. The COT is essentially a hopped-up Electra Distortion. I replaced the COT's BJT with a JFET, added a clipping option and active tone controls similar to the BB Preamp.
It's still early days, but I'm pleased with the results so far. Q1's Vgs,off is -2.1V. Any JFET in that neighborhood should work. Like the COT, the GAIN control varies both the negative feedback at Q1's source as well as the bias point. This helps keep the clipping fairly symmetric as the GAIN is turned up. With the CLIP switch in the OFF position, the first stage runs clean at low GAIN settings. The LEDs are always in the circuit and cause Q1 to limit gracefully instead of saturating. When the CLIP switch is in the ON position, the Si diodes are engaged and we get some smooth, mostly symmetric clipping. I placed the VOLUME control between the 1st and 2nd stages to maximize the available headroom. The 2nd stage is a variable Mid Boost centered at 750Hz. I "borrowed" that part of the circuit from the DSM OmniCabSim. The 3rd stage is a James-style active tone stack, derived from the BB Preamp. The maximum clean output is 5Vp-p. This is not a high-gain pedal. It provides boost, tone shaping and some distortion when the CLIP switch is on. Any decent dual opamp will work; I went with the NE5532A this time around.
Left to right: VOLUME - BASS - MID - TREBLE - CLIP - GAIN
