fydo
- Build Rating
- 5.00 star(s)
Hello!
Huge thanks to @HamishR, @Chuck D. Bones, and especially @MattG.
This has been a long time coming! MattG was generous enough to send one of his PCBs back in May (Edit: actually it was April!). I almost had enough parts on hand to build it, but was just missing the relay, so I waited for my next Tayda order (and included a fancy UV print too). When I went to finish up the pedal I discovered I had somehow missed transferring the voltage regulator to my parts spreadsheet, so I needed to wait again for another order. Now that I finally had all the parts I needed I was able to put this wonderful overdrive together. The PCB is laid out nicely and I had no problems populating it.
When putting together the drill template and UV print, I wanted as much real estate for the massive logo as possible so I tried to squish the potentiometers up as high as I could. It was a very tight fit, and you can see I used some kapton tape to ensure I didn't short the DC power connections with the back of the Mid potentiometer.
This overdrive sounds great! It is a modified TSV-808. As Chuck Bones notes in his thread, rolling the treble back and bringing out the mids works nicely here (esp. compared to a Timmy)
This was my first build using a relay and momentary switch, it sure feels nice!
As thanks to HamishR, Chuck D. Bones, MattG and the community in general, I have shared my Tayda drill link here:
And my UV print file is attached.
Just keep in mind the tolerances are quite tight with regards to where I placed the potentiometers (I was prepared to need to off-board wire a film capacitor or two if needed, but thankfully that wasn't required)
Hope you all have a wonderful weekend!
fydo
fydo
