TO-5 Sockets
Yup — I prefer the little pucks but don't think they're worth the bucks, bend over here come the ...
... solder them you say. What if I want to try some other transistors and experiment a little or a lot?
Isn't why everyone is always talking about breadboarding it first? I've only heard a difference in a couple circuits and most pedals sound and play the same regardless what gets put in. Of course YMMV and all that.
I have a Tonebender board I am putting together and I want to be able to play around with transistors before committing and I don’t want a circuit to live on a breadboard permanently. I think I might have one board as a tester board with sockets before soldering the transistors into another board.
I feel your pain. I was going through this too. I swear with germaniums there’s a difference in sound between testing in the circuit on the breadboard and then in the circuit on pcb or point to point or whatever. Sockets are the way to go and I wish the TO-5s weren’t so bloody expensive.
No Knead with sockets...
Seriously, though, there are times I breadboard (gonna change-up/try a ton of shite) ...
and other times I prefer to socket (build is done/fixed).
Instead of wasting time on breadboarding the whole circuit when I know all I want is to try different transistors.
Yes, most of the time the circuit sounds the same whether you stuff in a 2N3904 or 2N5088 — but not if its a BC239, maybe, sometimes.
Not for the visual perfectionists but you can use double row SIP style sockets, snap off a 3x2 section and then snip off 1 bottom pin on one side and 2 on the other side. Sorry in advance for shit photo, was running out the door!
You can also do this with double row headers but they’re more work than snapping, but you can also just gank the unused pins out really easily.
A TO-18 can be made the same way by snipping off a corner pin on a 2x2
I think I found some of those for cheaper but now I can’t figure out from where. I’ll let you know if I ever do.
