Thanks @Betty Wont$1.70 at stompboxparts and small bear are the cheapest I've seen them.
Isn't why everyone is always talking about breadboarding it first? I've only heard a difference in a couple circuits and most pedals sound and play the same regardless what gets put in. Of course YMMV and all that.Yup — I prefer the little pucks but don't think they're worth the bucks, bend over here come the ...
... solder them you say. What if I want to try some other transistors and experiment a little or a lot?
I just went through this, and what I did was install a socket, try some transistors, removed the socket and soldered the transistor in... solder them you say. What if I want to try some other transistors and experiment a little or a lot?
I feel your pain. I was going through this too. I swear with germaniums there’s a difference in sound between testing in the circuit on the breadboard and then in the circuit on pcb or point to point or whatever. Sockets are the way to go and I wish the TO-5s weren’t so bloody expensive.I have a Tonebender board I am putting together and I want to be able to play around with transistors before committing and I don’t want a circuit to live on a breadboard permanently. I think I might have one board as a tester board with sockets before soldering the transistors into another board.
