Synchrony Pedalworks
I was making a Guitarpcb Pump'd up Tonebender, v4. I am able to get fuzz, but it is sputtery/gated and at a lower volume. Below are my voltages for the IC and germanium transistors. I am worried that I blew two transistors (Q1 and 2). My father, who is a EE, walked me through the process to test the transistors with a volt meter, comparing the resistance of the B to each C and E. I am confused how the pedal can potentially have two blown transistors and still work, creating fuzz (yet bad fuzz). The transistors were matched for Q1 and Q2. Q 3 has the highest hFe. To test, I swapped out all the transistorss with a 2n3906 (PNP) transistors, but I still received poor fuzz.
Do these symptoms appear consistent with blow transistors or could the problem be elsewhere? To me, it sounds like a biasing issue. Any suggestions are appreciated. Thanks for your time. -Andrew
Power supply: 8.85 V
IC 1: 8.66 2: 4.59 3: 0 4: -3.97 5: -8.51 6: 2.53 7: 1.43 8: 8.66
Q1 B: -0.01 C: -8.43 E: 0
Q2 B: -0.16 C: -8.43 E: 0
Q3 B: -5.04 C: -0.44 E: -0.32
