Paul.Ruby
Have been comparing several versions of active EQ (Tone Tweq, Cold Turkey, Box 'n' all, 6-band) and keep going back to the volume-only preamp. There is something about the active EQ I don't like. It's a bit unnatural feeling in comparison. But I want a bit of tone control. So, I built a tried-and-true passive tone stack with Marshall values. This really feels right. Sounds right. It's a guitar amp. This includes an option for a bright switch but I'm going to build without the switch and use a 120pf bright cap (C4), leaving out the switch and C6. Spent the morning getting the tone stack and bright cap chosen just right.
The expressPCB layout has two versions. I don't seem to be allowed to attach a zip anymore... ?? One with pots on copper side and one with them on component side. Building at home on single sided board makes the copper-side version very difficult to solder. I learned this the hard way, but I have one instance of that built up and in a case. Pictured here has the pots on the component side. This is easier to build but careful not to use components that are too tall. Note the 1uf cap laying on it's side and use of a surface mount electrolytic cap with it's base removed to make it through-hole. This will fit in a 125B case. I've ordered some right-angle header pins since can't use regular headers with this board. I might just hard wire this one. The LED resistor is not installed because every LED I try needs different current to get right. I still have LEDs from the 80s (I'm old) that draw 20 times more than this whole preamp... and modern super bright that seem to turn on if I get them near an outlet... Still too bright even with a 1M resistor.
