gonzo
I've made a simple tube overdrive with a single 12au7. Which has a 9 pin that can split the two heaters in pins 4&5 to run in parallel. So I can run the two heaters at 6 volts each to total the 12 volts the tube likes to see. In series I run it at 9 volts and it still sounds great, just less headroom. I've got an idea to switch between 9 volts and 6 volts. Some people have used a voltage regulator to achieve this. But it seems like this would add even more heat to the pedal
So my questions
1. Wouldn't a voltage divider work? And possibly cut down on the heat.
2. If I have to use a headsink in a regulator, would it be better to add vents near it or actually have more metal for it to radiate to?
3. At 9 volts the tube isn't very hot. At 12 I'm a bit worried building a wood sided metal top pedal. I'll add vents. Much like an amp head just more compact. Anyone tried a half wood enclosure with tubes? Any issues? Wood glue melting?
Thanks for any tips.
So my questions
