Two new builds - By Request - CONTACT (PedalPCB) and ANDROMEDA (Aion)
GenoBluzGtr
I built these two on request from a friend. He tried the first two that I built and had to have copies for himself. One of these is an Aion and the other is Pedal PCB - but I'm posting together because they're VERY complementary and would be a great one-two punch for any pedal board.
First up is the Aion Andromeda - I've named mine "Atydum" - it's latin for "innermost sanctuary" and playing this circuit does that to me. It's so nice and "grind-y" but without saturating. Light picking = light, thickness on your notes, dig-in and it like the most fantastic tube-screamer with balls you've ever heard. Loads of low-end, but easily controllable with the bass cut switch.
The second one just blows me away at how touch-sensitive it is... the "Touche", using a PedalPCB Contact board. This circuit is pure magic. It cleans up (even better than the Andromeda!) and has a larger range of gain, but has a different tonality to it. It cuts better, even with higher output humbuckers, and has exemplary string clarity even when pushed really hard. HIGHLY recommended.
¿Hola Me pueden ayudar? Construí mi proyecto de toque, pero no me parece mucho, puedes ayudarme si los números de los componentes son correctos en los condensadores.
