adambricks
I recently built an uberfuzz and have it cutting in and out. The diodes on my board are printed as going the same way, also I have used 2N5088 transistors swapping the collector and base to fit the 2sc pin out. I’ve checked both pots in circuit, one is getting a consistent resistance reading while the other is hanging around 8k-11k no matter how I turn it. Could this be an issue with the pot or is the lack of a good reading on the balance pot because it is in circuit? The pedal is cutting in and out and making a lot of strange noises. Any help is appreciated. Thanks
