F FancyEspresso Member Jun 11, 2021 #1 Hi what is the pinout from left to right on the Uberfuzz PCB for the 2sc828? Trying to replace it but Google has two conflicting pin outs
Feral Feline Well-known member Jun 13, 2021 #2 Different manufacturers may have different pinouts for the same part number/component. See if you can dig up the datasheet for your component.
Coda Well-known member Jun 13, 2021 #3 I believe it’s ECB. I built an UberFuzz last month. Worst case: use sockets and adjust as needed.
Chuck D. Bones Circuit Wizard Jun 15, 2021 #4 The transistor part number is not critical in that circuit. The usual suspects (MPSA18, BC549C, 2N3904, 2N5088, 2N5989, etc.) will work fine, just mind the pinout. Attachments 2SC828 - semtech.pdf 2SC828 - semtech.pdf 211.5 KB · Views: 51
