p_wats
That's the way it will work, as if you're in bypass then you're also bypassing the buffer, so no single will be getting to it. (ie. The dry out will only work when the pedal is on). It's a limitation of this quick and dirty mod.Hey, so I tried this on an organ donor. I'm taking a line from the buffer (IC1, pin 1) to a separate mono jack to use as a dry out. I have a wet and dry when the pedal is engaged, but no signal comes through the dry output jack when bypassed.... Am I missing something?
