Dirt_diggler
Hello, i am using an order switch with a pauper and kliche mini for a 2 in 1. However i was having trouble understanding s1-s6 on the switch holes on the kliche PCB side. I usually see in/ground/switch/out for other PCB to switch then the switch has a separate wire to in and out respectively.
I see an in and out hole on the PCB towards the pots. Just trying to figure out which of these holes needs to go to the order switch board.
