DGWVI
- Build Rating
- 5.00 star(s)
Just a quick one to demonstrate the Amazon 8038 (featured in vid). I built 2 at once to compare 8038s, and they function identically.
This is an awesome, simple Trem. Im really quite enamored with the Square Wave mode, but the Tri and Sine are also pretty pleasing. Almost gets up into ring mod or fm territory, but not quite. It does bring the stutters and wobbles, though.
The trim pot is pretty touchy, and needs to be set just right for minimal distortion in the Sine and Tri modes.
Otherwise, super quick builds, made possible by @Robert's awesome layout.
No mods to these ones, but if you want a variety of speed ranges, you could put the 220n just below the 8038 on a switch- lower values = faster speeds, higher values = slower.
There are some other things that could be done to effect the symmetry of the waveshapes, but I haven't experimenters with those yet
Being a Fran circuit, I have to recommend this one, especially if you're a fan of tremolo effects. I'll be using one of these in my envelope trigger chain, and possibly another in my HOG signal chain
Note that regardless of 8038 source, you will need to lift pin 6 out of the socket. The chip will not function properly at 9v with this pin connected.
