DGWVI
- Build Rating
- 5.00 star(s)
Another one of these wobbly guys for a commission.
Here's a sketch of the speed toggles wiring
Fairly simple build, nothing to calibrate other than the BBD bias. I have the delay time trim set to eliminate whine introduced with the additional clock cap.
- Rate pot increased to 500kC for a wider range of slower speeds
- C22 & C23 are 33n (higher speed range than stock)
- DPDT on-off-on to add 220n caps in parallel with C22/23 (slows down the speed of the LFO considerably). Right position adds the 330n only to C22 or a warbly tape asymmetry, middle position is fast, Left is slow
- Bottom toggle adds an 82p in parallel to C24. Wires tack soldered to pins 5&7 of the clock chip to make the whole thing easier to put in the enclosure.
- IC1 is LF353 because that's what I have a ton of
