DGWVI
We got warpage
This is also the first Low Tide I've built that I didn't have to calibrate, so that's rad. The last one was a huge headache to get the BBD biased
Boxmate -
We got warpage
This came in yesterday. Guyatone FLIP envelope filter.
eBay "not working, as is"
$55 gamble. Plugged the toob back in as it was dangling by a couple pins and fired right up. Sounds, well, funky on bass. These seem to be a rare dog in the FLIP series.
Wasn't on the bench long but hey. Take the easy ones when you can get them.
@vigilante398 or anyone else want to trace it before it's likely off to reverb or sent to the trade shelf? I think there are schematic scans out there already though.
What’s in the stock pot?Not quite a mile. That bench is 16 feet long though.
Nothing you’d want a ladle of! It usually sits full of soapy water under my big belt grinder to catch most of the sparks and dust. It turns into a pretty gross rusty muck.What’s in the stock pot?
They have their place!
The long procrastinated beater bari Jericho overhaul. Off to a rough start.
Had a JB/SH-4 with a cover in the bridge that was just too dark and loose in the low end. Great for sludge and doom but terrible everywhere else.
Have a Black Winter going in.
Well, it was. Have I mentioned I hate direct mount pickups? No room for a ring here and damn if (I) didn't strip the upper mounting hole.
***Anyone have any good fixes? Toothpicks and wood glue and redrill is my current guess.
This and the fact that it destroys the threads on the pickups is why I hate direct mount. That and finding the right size foam. I tried using some black esd foam and it was just a hair thicker than the old stuff glued on the JB, which was too low. We'll see how it works.
Also going in is a Freeway 5/10 way switch and a preamp/volume control combo from @JTEX
Once I unshrink my hole that is.
Second bench fail today.
Fist was an old Dinky I was going to loan a friend on hard times. Replaced a bad jack first. Well. It's bridge pickup(emg hz) is dead. Measures at 2 megand has 10% output.
Same here. I have a box just to keep broken-off pot tabs in for this purpose+1 They have their place! ^^
I use the tab broken off and wedge it in the split of the pot (if still loose, then a dab of solder keeps it in place) —
that way when I use a set-screw knob instead of a splined friction-fit knob, I don't smush the pot's shaft tightening the knob's set-screw. Here's what I mean.
I fit a "dowel" with a cross cut in it with wood glue. It got a little[le tight at the end but worked.Try woodfiller — it's basically epoxy with sawdust, the JB-Weld for wood.
Take a scrap of similarly grained wood and experiment first. Some woodfiller just breaks down under the bit when re-drilling *(maybe due to heat?). Anyways, like anything, some fillers are better than others.
You've gotta fill the entire hole, insert a bit at a time and squish it down each time so you don't have any voids.
But then you would have to change your name to garage david instead of laundryroom david…. It just doesn’t have the same ring or mystique as laundryroomdavidAbsolutely nothing on my bench. Still clean and bare from the great clean-out of ‘23. One too many fights with my wife over “the mess” and my encroachment upon the laundryroom, which is the only space in the house I could actually build in. I bagged and boxed up all my supplies. On the upside, no build reports from me for a while! I might insulate my garage and move out there![]()
Feel you. I had a couple things go wrong recently (pedal and not pedal related) and now my kid won't sleep so I'm ready to throw it all out the windowAbsolutely nothing on my bench. Still clean and bare from the great clean-out of ‘23. One too many fights with my wife over “the mess” and my encroachment upon the laundryroom, which is the only space in the house I could actually build in. I bagged and boxed up all my supplies. On the upside, no build reports from me for a while! I might insulate my garage and move out there![]()
Kids... sometimes they make you want to just set everything on fire.Feel you. I had a couple things go wrong recently (pedal and not pedal related) and now my kid won't sleep so I'm ready to throw it all out the window
It’s an empty threat. I’m wayyy too cheap to insulate my garage.But then you would have to change your name to garage david instead of laundryroom david…. It just doesn’t have the same ring or mystique as laundryroomdavid
Pro tip from experience: open the window first.Feel you. I had a couple things go wrong recently (pedal and not pedal related) and now my kid won't sleep so I'm ready to throw it all out the window
