Standing resistors?
I watched a Franlab video where she talked construction methods, and If I remember right was making an argument that offboard wiring all controls and connections has some potential advantages in lower mechanical stress on the pcb/ longevity.Offboard wired pots?![]()
I laid out my own board for a SS/BS mini, and as expected had a load of PCB from china made....I watched a Franlab video where she talked construction methods, and If I remember right was making an argument that offboard wiring all controls and connections has some potential advantages in lower mechanical stress on the pcb/ longevity.
I certainly don't want to build anything with offboard wired pots, but I respect it when I see a commercial operation doing it, since I assume they must be doing it with quality in mind? It must cost more to do it that way right? It seems like builders who have optimized for labor cost are board mounting everything.
honestly, i agree.I watched a Franlab video where she talked construction methods, and If I remember right was making an argument that offboard wiring all controls and connections has some potential advantages in lower mechanical stress on the pcb/ longevity.
there's nothing wrong with offboard anything if it's routed and wired with care and thought.
Lollar does.If they're charging top dollar, Lollar should have some self respect and put some cat hair on that double sided tape.
Now I get that tortured look from the dude in the demo video.It very well could be. I don't love it.
No offense to mooon, it wasn't designed with my tracing pleasure in mind and is a nice tight layout... but standing resistors? I'd rather you just goop it.
I'm not particularly blown away by the construction, which is ironic considering it is literally made out of cast iron. There is hot glue, double sided tape, and offboard wired pots. Lots of flux, which doesn't bother me, but would bother some.
One thing I was interested in seeing is how the "dry out" was implemented...
Are we tapping off of the preamp stage? Is it a completely separate circuit?
Turns out it was much simpler.
So I was on the free the tone (the Japanese company) website and noticed in the selling points of one of their pedals :I'm not particularly blown away by the construction, which is ironic considering it is literally made out of cast iron. There is hot glue, double sided tape, and offboard wired pots. Lots of flux, which doesn't bother me, but would bother some.
- Casing Design*: All of the parameters of a case -dimensions and plate thickness of the case – affect overdrive sound. We employed the best size case for our Integrated Series to provide the ideal sound. Its weight has also been optimized to deliver the best sound.
*Because a pedal’s case provides a signal ground (0 V) and shielding, changing the material, size and thickness of the case can change the sound of the pedal.
The capacitance between the case and any signal lines inside the case can also affect sound quality.
Which they then explain
Just think how wrong we’ve been getting it with these aluminium boxes and how much tone upgrade we could all have?!
We made fun of those sections a lot a few years agoSo I was on the free the tone (the Japanese company) website and noticed in the selling points of one of their pedals :
I have no idea what I would have had to search for to come across that!!We made fun of those sections a lot a few years ago![]()
- FREE THE TONE Custom Knobs: We developed a custom turned brass knob to reduce vibrations in the shaft and wiper of the semi-fixed resistor used for each control and suppress harmonic components that might adversely affect sound.
In theory, no knob would resonate at a higher frequency, having less mass...If this were true, wouldn't no knob at all be a better solution?
