Causefarley
Anybody know where to get these?
thank you!
stompboxparts.com carries a 20K W taper, probably as close as you get
A homegrown pot is the best. I started buying only 1MΩ and reducing. Makes ordering MUCH easier.You could also use a 50K pot and solder a 50K resistor across it to get 25k
Right. I use 1M because they are typically the highest values used. The resulting resistance will always be a bit lower than the lower value resistor used (except when 2 of the same value are used).Just to make sure I'm getting it right b/c it sounds genius: doing that w/ 1MΩ is just calculating the missing parallel resistor value between 1MΩ and the target pot resistance right and then connecting it to pin 1 and pin 3?
edit: well I guess any value but man the math is easy for 1mΩ
Google "parallel resistance calculator".
HA HA HA HA HA HA HAA homegrown pot is the best. I started buying only 1MΩ and reducing. Makes ordering MUCH easier.
Bad idea. It messes up the taper. Pedals that use W taper usually need the W taper.You could also use a 50K pot and solder a 50K resistor across it to get 25k
Isn't the taper decided by the thickness of the carbon layer at the position of the wiper?Bad idea. It messes up the taper. Pedals that use W taper usually need the W taper.
Does parallel resistance have a different effect on a circuit than linear resistance?Yes, for a bare pot. Adding resistors in series and/or parallel changes all that. You have to look at the bigger picture and consider how the pot's impedance varies with rotation and how that affects the rest of the circuit.
As I understand it, the taper is determined by the thickness of the carbon trail along the path of the wiper. The thicker (wider) the larger % of the whole is seen durinng rotation, and visa-versa.
How is a Resistor going to change the thickness of the carbon trail along the path of the W wiper?As I understand it, the taper is determined by the thickness of the carbon trail along the path of the wiper. The thicker (wider) the larger % of the whole is seen durinng rotation, and visa-versa.
