Harry Klippton
Not Interested
@Rpschultz13 what do you think the advantages of 9mm pots are? Especially when Robert doesn't use them as the default on his layouts.
I’m not exactly sure, certainly not advocating for them. Just trying to understand, which is why I started the thread.@Rpschultz13 what do you think the advantages of 9mm pots are? Especially when Robert doesn't use them as the default on his layouts.
Or BetaMax compared to VHS… or HDDVD over BluRay12mm pots = the metric system
Might be better in EVERY way, but it’ll never stick.
The whole world uses the metric system. It definitely stuck. It's just the USA that is having a hard time with the last 25% or so of the switchover12mm pots = the metric system
I was always under the impression that with a smaller pot the rate of change is more with every degree of turn so they can be harder to dial in a finer settingthe knob
The rate of change is dependent on the ole fulcrum and lever.I was always under the impression that with a smaller pot the rate of change is more with every degree of turn so they can be harder to dial in a finer setting
@Robert is correct. They both have their place. I don't think this is a case of which is better, but rather which is right for a particular application.They have their place. The Paraphrase layout, for example, wouldn't be possible with 16mm pots.
One benefit would be size constraints. For 1590A builds with more than 1 or 2 pots, they’re a must! Another is sturdiness on the PCB. If you have the space for the stabilizer tabs, there’s less of a chance the legs will flex and break than on a 16mm with flying leads.What's the benefit when they're twice as expensive?
