VIIB
Bio77
Man, this pedal fricken rocks. I think Bugg nailed this one. The relay bypass is elegant and works perfect.
I think classic mode is required, in true bypass mode you can hear the pedal come in and it kills the vibe (see what I did there :D ). Classic mode is dead silent.
I set the clock at 120kHz, in case anyone was looking for that ( I couldn't find it on the forum).
A few more questions if you don’t mind.
Did you use a 470k trimmer or a 500k?
Did you use a 200pf or 220pf for the 200pf position?
SKU A-3208
This the correct c250k pot?
And finally what Led did you use? 5mm
The pot and LED are correct. You can use a 500K. I used a 200p.
I snoozed on the relay while building up an order due to shipping fees. Is there another replacement for the relay?
I don't know off hand, I found the one I use by searching mouser with the specs of the panasonic relay. I know that 4.5V will also work. Just make sure it's latching. Tayda has one but it's non-latching and won't work.
