Hey Legends!
I've run into some issues when assembling my first Pedal PCB build. From the audio jacks I have the signal from sleeve to sleeve but not tip to tip - any idea on how to find out exactly where the issue lies?
No sound in bypass. I'm thinking the issue must lie somewhere between the tip to the tip haha (so anywhere really)So you don't pass sound even in bypass?
Thanks,I think the bottom row of your switch is wired incorrectly. It looks like it connects to the central pin rather than bottom right. Check it against the build doc.
haha beat me to it, was just trying to screen shot the doc. yeah the switch is wired as the diagram specified and the light switches on and off but no sound
Thanks,
This is not a true bypass circuit.No sound in bypass is either jack or switch related.
Maybe if you have a fancy one, but unlikely.is that on my multi meter?
Ive never come across this one eitherHow does the bypass work in this circuit?
Bottom lugs connected is "On", i.e. LED connected and P1 to ground.
What is the bypass state then? Ground is lifted and P1 connected to P2. I've never seen this configuration before.
Check this for some info:What is the bypass state then? Ground is lifted and P1 connected to P2. I've never seen this configuration before.
