Not sure if you meant that as a joke because it can turn into a bee hive of noise, or irony comparing to the few components of a fuzz face.So it’s a Fuzz Face…
The big metal box below the pedals, still needs a lot of workwhat are you using for your mega-enclosure?
Got it. I thought you had everything laid out on an industrial table. Looks like you will have enough room to build in the power supply, usb chargers and a back-up battery bank.The big metal box below the pedals, still needs a lot of work
I'm close to a "holistic" knowledge of electronics, more of a paint-by-numbers kits, so that's above my paygrade. That is the reason of the somewhat dumb question about loops on the other thread. Still thinking about dropping in a few more pcbs inside. Power supply will be outside, will not power everything with one cable, but most likely an isolated power supply. Battery bank is a nice ideaGot it. I thought you had everything laid out on an industrial table. Looks like you will have enough room to build in the power supply, usb chargers and a back-up battery bank.
Just belowThose are going into one giant enclosure?
44cm x 32cm, or apples for the americans and their imperial weird thingggyAwesome project!
If ever you start having doubts or lack motivation to continue, search the Internet for "VFE Mega Pedal" and carry on.
What is the length/height/width of your enclosure and where did you get it?
No.Insanity?
