What the butt is that for??New addition to the Peak LCR45...these are real useful. The LCR-45 already had the micro-bananas, so an easy upgrade!
The tweeze makes measuring components a breeze.What the butt is that for??
I mean what's it measure?The tweeze makes measuring components a breeze.
I'm sorry Will. It measures Inductance, capacitance, and resistance. My DMM does the latter two but in a much smaller range.I mean what's it measure?
It needs a new spindle attached to one of those blades. The bearings are becoming unbearable and I've decided not to resuscitate once it seizes. I've got a feeling I may be too busy for much yard work this summer anyway.…and whether or not your mower blade needs sharpening…
Good question.How does it differentiate from your DCA75? .... Or in which situation would you use one rather then the other?
Got it! I though the DCA75 could mesure resistors and capacitors so the LCR45 is a nice addition! Dam it .... another tool on my wish listGood question.
Here are some key differences;
The DCA75 does not measure LCR values (inductance, capacitance, resistance) but the LCR45 does.
The DCA75 will measure transistor specs but the LCR45 does not.
The DCA75 will measure diodes but the LCR45 does not.
Daddy likeI'm sorry Will. It measures Inductance, capacitance, and resistance. My DMM does the latter two but in a much smaller range.
It does. Always.…and whether or not your mower blade needs sharpening…
Oh wow. That's really impressive.Another good question. Here's the spec-sheet.
Coming up next.....
That's my answer to Vanna White.
