Chuck D. Bones
Circuit Wizard
Rat & TS are obvious choices.
For a more advanced build, how about one of the Revv or Friedman pedals?
There are things in the Friedman circuit I'd love to understand (like how the tight controls work).Rat & TS are obvious choices.
Ask and ye shall receive...There are things in the Friedman circuit I'd love to understand (like how the tight controls work).
You're the best!
Since I am building the OD-1.. I wouldn't mind seeing the SD-1 that PedalPCB has and a little comparison on the differences.Reviving this older thread. Are there any requests out there for any particular PPCB? Or if not a particular circuit, possibly how to breadboard a certain circuit block (i.e. EQ section)? I would love to contribute to this community in any way I can that would be helpful to anyone.
I literally just ripped apart my blues breaker on my breadboard to breadboard Chucks digital reverb. Its a monster not quite done with it yet but its fun building nonetheless!I’ve currently got a blues breaker on my breadboard and plan on (when I stop with other projects). Piecing together differences from the Parthenon and glory hole. Taking this and that making other changes a long the way. I’m not breadboarding master though. But I feel like things like this would be beneficial taking the core circuit and looking at what changes were made with pedals based on it.
Oh boy I think your yellow jumper is in the wrong stripI literally just ripped apart my blues breaker on my breadboard to breadboard Chucks digital reverb. Its a monster not quite done with it yet but its fun building nonetheless!
I have to run through it again somethings wrong....thats tomorrows quest....
So i thought the same thing in fact i actually breadboarded to figure out how to add more gain ended up not taking far cause i just played itWhat were your thoughts on the blues breaker. I have the old school one on right now. Seems bright and lacking gain the little bit I’ve messed with it so far.
 then ended up ripping it apart today after it sat there for like a month. Going to breadboard it again in the future. Interestingly enough though i remember using 2 Tl071s cause i was out of Tl072s. It sounded ok but i wouldnt recommend it its just more work to get the same result.
 then ended up ripping it apart today after it sat there for like a month. Going to breadboard it again in the future. Interestingly enough though i remember using 2 Tl071s cause i was out of Tl072s. It sounded ok but i wouldnt recommend it its just more work to get the same result.Yea I want to play with like the gain switch from the Parthenon and adding the cap like the glory hole to the clipping stage. My understanding is that 6k8 in the clipping stage is to allow clean signal to pass not clipped thought like a 1-2k with a 5k pot might be cool there.So i thought the same thing in fact i actually breadboarded to figure out how to add more gain ended up not taking far cause i just played itthen ended up ripping it apart today after it sat there for like a month. Going to breadboard it again in the future. Interestingly enough though i remember using 2 Tl071s cause i was out of Tl072s. It sounded ok but i wouldnt recommend it its just more work to get the same result.
Very cool ideas. Im a fan of the JHS morning glory. You should also add the high/low pass filter like the Morning Glory im a huge fan of that and feel like every blues breaker variant should have it hahaYea I want to play with like the gain switch from the Parthenon and adding the cap like the glory hole to the clipping stage. My understanding is that 6k8 in the clipping stage is to allow clean signal to pass not clipped thought like a 1-2k with a 5k pot might be cool there.
