Hello, I'd like to order from Digi-key, which should be the right LDR and bulb for the build?
This is the bulb I find:
This one is the 9203 but you said that specs are different:7371 Visual Communications Company - VCC | Optoelectronics | DigiKey
Order today, ships today. 7371 – Incandescent Lamp Clear 12V Round with Domed Top RT-1 3/4, 6mm Radial - Bi-Pin .125 from Visual Communications Company - VCC. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.fr
PDV-P9203 Advanced Photonix | Sensors, Transducers | DigiKey
Order today, ships today. PDV-P9203 – CdS Cells 520nm 10 ~ 30kOhms @ 10 lux from Advanced Photonix. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.fr
Cheers
Actually, before ordering from Digi-key I realized Banzai has the correct bulb as per the bill of material.
Cheers.
