Beautiful work! How did you make the light shield?Hey boys and girls,
I just finished my ElectovibeBuilding was great and it works like expected!
I attach some pictures.
Jimi
Nice build!Hey boys and girls,
Jimi
Noob question: how do you connect the pin headers on the PCB to those on the breakout board?That’s a slick idea. Although, I’m sticking with the breakout board because I’m using pin headers to eliminate the hookup wires and make everything look cleaner.
Well, there’s pins on both sides. So one side goes to the main board and the other to the breakout board.Noob question: how do you connect the pin headers on the PCB to those on the breakout board?
I've been seeing those red electros on boards everywhere lately.
So you put the pin headers in the pads on both the PCB and the breakout board but how do you connect the two boards together? Do you use one of those ribbon wires with the white plastic female connector like they use in wah pedals?Well, there’s pins on both sides. So one side goes to the main board and the other to the breakout board.
In my case I’ll break off a 1x3 and 1x4 because I’m running a jumper from the ground pad to my switch for enabling the bi-color LED.
DIY with a thin aluminium sheet and an exacto knifeBeautiful work! How did you make the light shield?
As for wiring the bi-color LED I'll have to process it a bit longer haha. If you weren't doing that you would just use two 1x9 headers, right?
Of course, so the boards will simply overlap. Here I was picturing all kinds of wiring haha.They have pins on both sides:
Thanks!
The overlap or the wiring?Nope! That's what I'm hoping to eliminate!
Thanks for the patience!The wiring.
Terrific builds on this thread!
For people who have already built an electrovibe: could you point me to the LDRs and Bulb you have used?
I just received my PCB today and I'm in the process of ordering the components, but hadn't any luck finding 9203 or 7532 LDRs anywhere.
Also, would Mouser 560-7371 bulb be correct?
