Big Monk
Does anyone know what the dimensions would be for the square hole lever switch version?
Search the ElectroVibe threads. The switch brand is listed in there somewhere. Then you can pull the data sheet for dimensions.
Anyone know of a U.S. supplier for the bulb and LDRs now that small bear is out of stock? For some reason I’m not able to order thru Banzai
Thanks for the heads up! I should easily be able to find more than $20 worth of stuff to get from jameco.Mouser has the bulbs.
Digikey has 9203 LDRs but they are actually 9200 spec.
Jameco has legit 9203 LDRs and the bulb but a $20 minimum.
