vigilante398
Authorized Vendor
I have about 50 Black Eye PCBs back in stock. I have a dozen or so enclosures on hand and will be getting more soon, so enclosures will continue to be an option.
I'd be on it if I wasn't in Europe. I can't believe we have multiple vehicles on Mars but shipping and import taxes are still so expensive here on EarthI finally got around to organizing my Space Heater PCBs, so those are available now as well. I have 25 in stock and plenty of enclosures to offer enclosures for those as well.
Right, the shipping rates generated by the website are based on dimensions of a full pedal, so with a box it would be about the same but if you're just buying a board I should be able to get it to you cheaper. I'll take a look.I'd be on it if I wasn't in Europe. I can't believe we have multiple vehicles on Mars but shipping and import taxes are still so expensive here on Earth
I'm sure you'll have no trouble selling those out as well!
You go first.....I too got two. Not because I had to, but because he had two.
I look forward to building them.
Sweet, got mine ordered. Now to find some tubes.I have about 50 Black Eye PCBs back in stock. I have a dozen or so enclosures on hand and will be getting more soon, so enclosures will continue to be an option.
I also wanted the enclosure since I can'tRight, the shipping rates generated by the website are based on dimensions of a full pedal, so with a box it would be about the same but if you're just buying a board I should be able to get it to you cheaper. I'll take a look.
I also wanted the enclosure cause I'm terrible at drilling but I'll sit this one out for the time being as ordering just one product doesn't make sense financially.Right, the shipping rates generated by the website are based on dimensions of a full pedal, so with a box it would be about the same but if you're justbuying a board I should be able to get it to you cheaper. I'll take a look.
So if you're running the tube filaments at 6V (parallel) you need about 300mA, at 12V (series) you need 150mA. If you run it in series you can get away with running it down around 9V, and that will pull around 110mA or so, that's usually what I opt for.I'm contemplating just buying one or two of the high voltage supply boards for right now since I have a few sets of simple 12Axx boards of my own design kicking around already and Tone Stacks 'R Us, pretty much. What's a reasonable line in the sand on current supply, both HV and filament, please?
That said, the Black Eye looks like something I would enjoy a lot for guitar, but I don't even have a guitar amp at the moment. so...
Thanks man. I might be wanting to run a 12AU7 or two pretty hot for one bass line driver build I have in mind, but a 12AX7 noise toy is certainly in the mix too. In any case I'm used to over engineering things a bunch, so I always ask things like this...LOL!So if you're running the tube filaments at 6V (parallel) you need about 300mA, at 12V (series) you need 150mA. If you run it in series you can get away with running it down around 9V, and that will pull around 110mA or so, that's usually what I opt for.
HV you really don't need much, a 12AX7 plate only pulls 1-2mA in typical applications.
I rarely find time to play the guitar anymore, but when I do Black Eye comes out 100% of the time.
12AU7 can pull harder on the plates, looking at the datasheet max plate current is 20mA, filament numbers are the same though.Thanks man. I might be wanting to run a 12AU7 or two pretty hot for one bass line driver build I have in mind, but a 12AX7 noise toy is certainly in the mix too. In any case I'm used to over engineering things a bunch, so I always ask things like this...LOL!
I might want/need in the neighborhood of 15-20mA total on the HV side, max. I have all this stuff modeled in LTspice already and can just tweak the biasing as needed. I reckon I should just model the whole shebang anyway since this type of power supply isn't something I've built DIY things with thus far.12AU7 can pull harder on the plates, looking at the datasheet max plate current is 20mA, filament numbers are the same though.
Is your application bass or guitar? I have really different preferences between the two, even more so because all my basses use onboard preamps at all times. Hifi is my jam for bass, 100%.For tubes think I'll stick to ecc81/83's(12at7/ax7 respectively) either have warm tone or that good ol'70's crunchy.
Lol, I absolutely appreciate it, but a) I'm going to keep doing stuff whether people are buying or not, and b) the bulk of my R&D money comes from selling finished pedals. I'm happy to offer a limited number of PCB designs, but I have no plans to make it my main thing.Back to the thread, keep this man in Biz folks!! I want him to have enough cash to research/develop other classic tube amps in a box!
