MichaelW
- Build Rating
- 5.00 star(s)
Update: 12-16-22
@Robert has released a revised version of this board to address the "white noise" hiss reported by a number of folks.
The hiss was tolerable playing clean or with low gain but kick in a higher gain pedal and it got pretty distracting.
It was a shame because I really like the subtle coloring this pedal added as a boost. It wound up on the pedal shelf.
When revised pedal was released @Robert offered to send me a new board or try the mod to my existing build. Never one to back down from some squeamish surgery I decided to try the mod first.
I had forgotten that I had already semi-borked this board when I installed the wrong pot and pulled a pad removing it. So there was already a flying jumper to fix that. So what's a few more cowboy mods right?
Anyway, those of you that have built this pedal and want to try the mod, it's actually pretty simple and COMPLETELY addresses the "hiss" issue.
Here's the mod:
So as I was removing the 470n cap at C3, of course I pulled another pad along with part of the trace.....ugh....so I had to run a small jumper underneath the board and run the C3 leg to R2 output.
I decided to do the mod up top where I could have a little more room.
I was surprised as all get out when I fired it up and it all worked! Hahaha....
There is a "slight" attenuation to the gain. But this pedal had TONS of gain to begin with. I could barely crack the knob at the "High Impedance" setting.
With the mod there is still a ton of gain to push an amp.
At the High toggle setting, unity is now around 3 on the knob.
At the Low toggle setting (where there is a bit more coloration) Unity is around 5.
All with no noise.
So glad to put this sweet boost back into rotation!
Thanks @Robert !!
Original post from 8-9-22 below:
Double dipping on the build reports today.
I was originally planning to post a 2fer build report with these two pedals assuming they would be very similar.
But as I mentioned in my EV Preamp build report, the forum seemed kinda quiet this morning so I went ahead posted that build report separately.
Regarding the notion that these two pedals would be very similar, I could not have been more wrong. This is a very different pedal.
First off, there is a ton of gain in my build. To the point that I'm wondering if I did something wrong. I mean unity is literally about 2 on the amp knob that I used in Low mode. In High mode I can barely crack the pot and I'll be at unity. I don't know if swapping to a linear pot would help or not but I'm thinking about it.
Secondly, I am hearing a little bit of the white noise that @coltonius mentioned in his build report. It's in the background and is there when the pedal is engaged.
I can hear it when I play with my headphones but it's not noticeable through my amp or monitors, but it's definitely there.
Not sure if it's a charge pump issue or as @coltonius surmised a circuit noise floor issue. I don't find it distracting or anything but there is some hiss.
I imagine a real Boss CE-1 would probably do the same thing.
Tonally, it's what I expected, a subtle warmth to the tone and added girth. More noticeable playing clean than with drive. Paired with an overdrive or pushing an amp it sounds like a really hard punching boost.
I really like the way this sounds but somehow I need to tame the output, it's barely usable it's got so much volume.
Tight fit in a 1590B but mainly because my drilling was a skootch off, hence the toggle washer and slightly crooked PCB in the enclosure. Oh and I put one of the 470nf caps in upside down. These little things drive me nuts.
@Bricksnbeatles did you build yours yet? I'd love to hear how yours turns out.
Here's the mod:
All with no noise.
Thanks @Robert !!
