ferdinandstrat
Well, built it, sounds ok but it squeals like crazy. Maybe I should increase one of the 100pF caps?
If it squeals all the time there is a problem somewhere in the build. So please provide a bit more detail about when it squeals, whether it is only when the gain is above half, etc.
What happens if your Guitar is facing away from Amplifier, This is a High Gain pedal & are prone to Feedback if you are facing the Speaker.How hot is the signal going into your effect? Does it stop if you back off the guitar volume instead of turning down the gain on the pedal? I don't know the pedal so others may know if this is way out of bounds for the way it is supposed to work.
Did you use shielded IN/OUT wires for your build? For many hi-gain circuits it's a must.
T.
Connect jacks directly to the pcb. Do not cross in/out wires.
As pictured, Which side of the LED's does the Flat at the Base of the LED's Face
Does a buffer help?
I didn't use shielded wires either (it's certainly not a bad idea), but I would definitely try separating those In/Out wires as far apart as possible so they aren't overlapping each other.
Everything else looks fairly standard (although I didn't use green mylars for the 4n7 caps)... It may not have any relevance, but some of the pins of your TL074s are awfully close to the adjacent socket contacts because of how they are shifted. Did I ship you dual/quad adapters with this? It might be worth giving them a shot.
Does lowering the Volume make it stop oscillating?
