This is new? I build one that has an extra knob. Is this a revision?…
The layout has been updated and split into two separate projects, the Boost (18V / 3-knob) and Overdrive (9V / 4-knob).
Probably overkill since the circuits are extremely similar but I didn't want to do the whole "Omit this part, add a jumper here, substitute this value" thing.
I don't care what it is or what it does, a side knob is janky af.
So which one is mine?…
Yours is a sort of hybrid of the two that could easily be modified to fit either. You have the 18V VCC of the Boost, but the Master volume and component values of the Overdriver.
This reminds me of when I realized my tail wasn’t normal…
Don’t let anyone ever make you feel like there is anything wrong with your tail.
Dime the Volume, use the Gain control to control volume, you basically have the Power Boost.
Use the Volume / Gain like an overdrive, you have the Overdriver.
You can pull the charge pump and run it at 9V if you'd prefer as well.
I just wanted to make both options available... Some purists would prefer to not have the Master volume, other folks would prefer it.
Now I’m curious to see what differs between the reissues and if it’s consequential at all.
