Thanks for checking. Attached is the PCB and front and back traces (unverified).i think equinox has traced the good schematic , i have look and think it is ok from the trace i see
for this pcb : https://www.pedalpcb.com/wp-content/uploads/2022/08/MGMM.png
i have rename some component to corespondind to the schematicView attachment 33818
Are we tracing a pedalpcb pcb? It's come full circle.
I wish some gut shot of the actual pedal(s) show up. So, is the 4558 single or a stacked chip setup??
I built one some months ago. Build report for my Little Green Mean Machine is here . . . .Anyone built this?
When the pedal is engaged/led on, I get no sound at all.
I think I used two 3mm clear (red) with a low current of only 1mA or 2mA. Not even 20mA like most common LEDs.Try diffused green LEDs instead of red, for more headroom before onset of clipping.
Also/or try 1 red & 1 green.
I'm not sure how amperage affects the clipping; everything I've read about diodes clipping is about forward-voltage.I think I used two 3mm clear (red) with a low current of only 1mA or 2mA. Not even 20mA like most common LEDs.
Interesting read.I'm not sure how amperage affects the clipping; everything I've read about diodes clipping is about forward-voltage.
Taken from a random web-search:
A "volt" is a unit of electric potential, also known as electromotive force, and represents "the potential difference between two points of a conducting wire carrying a constant current of 1 ampere.
Way-back-when I read that diffused had a different FV than clear, but that was debunked here:
Diffuse or Crystal Clear LEDs in Distortion Pedals?
Preemptively let me say I think I already know the answer, because every diode-based distortion pedal I own, or build photo I see here/elsewhere uses the DIFFUSE ones. ...BUT... As I understand it, the diffuse LEDs are all just white LEDs with colored plastic housings. So if that’s the case...forum.pedalpcb.com
