MichaelW
As opposed to......? a moronic Relay Bypass?
1206 parts are super easy to hand solder once you've done a few, I don't even bother to break out the magnifier for those. And for me at least, they are often easier to swap out than through hole ones installed in plated through pads. Plus they come in tighter tolerances more or less by default. You'll do fine, I'm sure.
Ironically a few weeks ago that happened to me and I checked the neighbors mailbox (right next to mine) it was in there so I grabbed it. Mail carriers sometimes do that.nothing for me, the PO put my package in someone else's box and marked it delivered
what are my neighbors gonna do with the 500K pots and 5-way strat switch?
What kind of tubes and what are they going into?PedalPcb, Stompbox Parts, and Amplified parts all showed up today.
Tubes, Jewels, pots, and other randoms to wrap up the year. Equilux almost done.
A 12ax7 and a 12at7. Have two tube builds in process. Still working out the breadboard values but my goal is to have them finished before Xmas. Lol.What kind of tubes and what are they going into?
Nice, also got some 1206 in my near future…Cool mail today!
I got two orders of Ge diodes in from SmallBear taking advantage of the sale and the the availability of a pretty darn good selection of NOS diodes that aren't Russian, hahaha. (Nothing against the Russian diodes, but for a while there it was all I could get)
But the coolest is a trio of custom boards from @MattG!
These are hybrid through hole and SMD boards. He was even kind enough to send me the SMD components!
Since I don't have an easy bake oven like @fig I'm going to take a shot at hand soldering these................
But some cool boards, Matt's take on the BuffaloFX TD-X, Colorsound Overdrive, and Barber Gain Changer.
Super stoked about building a DIY Barber drive!!!
Thanks Matt!!
For two 10Got a link to these? The ones I got off Amazon are also SUPER long...I have to use a depth setting nut on the inside to get it to where I like it.
These are the ones I got from Amazon....it's a bit cheaper since there's no shipping for me. They've actually worked out quite well but they do have a long barrel. Still, they give you an extra nut to set the depth and it's workable as long as you're not trying to sneak it in under a board or something.For two 10
20
I've bought a few pedal-related items from that seller, they're good.
They look the same as the other pair I got.These are the ones I got from Amazon....it's a bit cheaper since there's no shipping for me. They've actually worked out quite well but they do have a long barrel. Still, they give you an extra nut to set the depth and it's workable as long as you're not trying to sneak it in under a board or something.
