Robert
Reverse Engineer
I'll get those schematics to you ASAP.
Could I get a drill template for the Octarock please?
Perfect! Thanks again!The diagram isn't drawn up yet but it's pretty straightforward.
+/- go to the corresponding lugs of the DC jack.
IN goes to Input Jack Tip
OUT goes to Output Jack Tip
Each jack grounds to their nearest GND pad
The two 3PDT breakout boards are direct pin-for-pin connections.
See this build report for an example:
Fordable Boost+Drive
Very straightforward build, @Robert said it’s a little tight, and it is, so you should definitely put the 3PDTs in first, solder only one leg of each pot, and then get everything test-fit first before tightening all the nuts and soldering all the pots (which I guess technically you should do for...forum.pedalpcb.com
Bumping for the Dual Effects Loop Switch schematic![]()
Yep… drill template the same as other 6 knobs like Sea machine?
Feel better @Robert and famSorry for the lack of responses, we're just getting over a week long illness here. Crawling my way back to reality now.
Quite a bit of shipping to catch up on, but I'll get these posted ASAP!
Hope you get better soon.Sorry for the lack of responses, we're just getting over a week long illness here. Crawling my way back to reality now.
Bottom = Rat = variable low pass filterCleric fuzz: Bottom is the rat. Middle is the muff. What the heck is the up position? Crazy cool but whaaaattt?! Also is the schematic available so I can understand the filters better?
